how bad is this damage to this mount
not bad, anyone who can weld should be able to fix that no problem. But while you got the motor out, clean up that bay! Now is the time to do it.
Out of personal expierence, spend the cash and the time and do things right. That obviously doesn't look normal. re-weld a new piece of steel to reforce it, clean it up, i would paint it, if your spending the time for a rebuild, then atleast touch it up a bit
You should probably delete one of these topics, since you have two for the same issue.
Also, I just fixed a problem like that last week, and I have pictures of it. I'll see if I can upload them here in a little bit.
Just grind down the area and cut a piece of metal out...then weld that piece of metal in to re enforce it so it will be strong...you should be just fine
