How a wide-band works.
preludeachris
295
3
Sep 29, 2011
Lincoln, Nebraska
Here is an informative bit on how a wide-band 02 sensor works,
Theory of Operation
The wide-band O2 Sensor operates differently than traditional O2 Sensors. The wide-band O2 Sensor tip consists of two cells that provide different functions, a measurement chamber and a detection chamber with pumping capabilities. The oxygen pumping function is the ability to pump oxygen into or out of the measurement chamber depending on the level of oxygen in the measurement chamber. This function provides the wide-band sensing capabilities and is critical for proper oxygen measurement. The O2 Sensor Reference circuit provides a common bias supply to both the O2 Sensor Signal and the O2 Sensor Pump Cell Current circuits.
During normal operation, the O2 Sensor Reference voltage and O2 Sensor Signal voltage will be a fixed voltage value. The O2 Sensor Current Pump voltage will switch from between 0.45 volts above and below the fixed O2 Sensor Return voltage, allowing current to flow in either direction through the pump. This correlates with the pumping of oxygen into and out of the measurement chamber. On a properly operating vehicle, this happens very quickly and the voltage reading should maintain a steady 0.45 volts when taking a voltage measurement between the O2 Sensor Signal circuit and the O2 Sensor Reference circuit of the O2 Sensor with the engine running and the O2 Sensor operating in closed loop.
When the exhaust stream has a lean air/fuel ratio (high oxygen content) the pumping element voltage will move toward +0.45 volts pumping oxygen out of the measurement chamber. When the exhaust stream has a rich air/fuel ratio (relatively low oxygen content) the pumping element voltage will move toward –0.45 volts pumping oxygen into the measurement chamber.
Again this is just a general idea the speifics may very according to brand.
Hope you found this helpful :thumb:
