Hotsync cables for Handspring Treo 90?
CJJohnWynn
Jun 18, 2007
Seminole, Oklahoma
I recently acquired a Handspring Treo 90 with Palm OS 4.1 and I have Palm'n'Stein already on it. I've been searching for about 2 days now trying to find out exactly what cables I need. I'm pretty sure I need one cable that plugs into my OBDI port and then another cable that will connect to the end of that cable and into my palm. Pardon the ignorance because I may just not be looking in the right place or calling them the right name when I try to search for them. Very new to all this so all the advice you could give is much appreciated.
*And on a side note is palm'n'stein the only software i need or are there others? Thanks!
You need a datalogger cable, they sell them on ebBay, pocketlogger.com, obdloggers.com, etc... However, they don't make dataloggers cable that are OBD/OBD2 to USB so you need to buy a serial Treo 90 Hotsync cable too and that all you need.
On a side note, you should try out the MMCD datalogger software too. I personally think that is much better than Palm'n'Stein.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
