90 shift cables
lilsam
145
Sep 28, 2011
Milwaukee, Wisconsin
Hey i was wondering if there was a install guide for shift cables? If there is and you could link me it that would be great. thanks
To remove,
gain access to the shifter by removing the center console
remove the two cotter pins holding the cables to the shifter
remove the holding nut about a foot down toward the firewall from the shifter
remove the two bolts holding the shifter cables to the inside firewall
remove the cotter pins on the transmission
remove the wedge locks from the transmission bracket
remove the cables
install is the reverse of removal
be sure that the shifter and cables are out the same year as they are different and will cause issues.
Its really straight forward once you start on it. Just make sure that you are careful when putting the new cables back through the firewall to ensure you dont brake the new ones. Do you need a set of 90 shift cables? I have a good condition set I would be willing to sell.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
