Hot Start and random missfire CEL irratic idle
KING4ADAY
71
May 27, 2009
muskegon, Michigan
my car is 7bolt automatic 97 gst running stock injectors 16g turbo, ok heres the deal i just got the car back from the shop it had some bad grounds coming from the ecu to engine bay they also did a smoke test for vacuum leaks when i got it back from the shop it still had a low idle under load and in park to the point my oil light comes on. well i drove it for about 3 days i then noticed that after driving it around town when i would go out to start it it would would attempt to start couple times and then no start but if i leave it for awhile it starts , seems to only do it when its hot. as well as one day when i went to start it , then started running roughly and rpms in park were 2 to 3k rpms and would slowly come down and almost want to die then my CEL came on saying RANDOM MISFIRE. i found an air leak at my intake manifold and repaired it and still no change , i called the shop and they told me to check Crank Angle Sensor . any suggestions and info would be greatly appreciated. like i said it just happened and has continued. i havent performed any checks yet. thanks in advance.
