Hose name
ROOKIE1
2,820
3
Aug 25, 2003
Walton, Kentucky
I have a leaky coolant hose and need it replaced . It is one of two hoses that go to the throttle body ? Need to know if they have actual names or part number . Or are they just coolant hoses ? Thanks and be gentle . OMG
take the hose off and bring it into autozone, pep boys, advanced auto ect... tell them the model, the year and if your car is front or all wheel drive and match up to make sure the hose is the same size and that should fix your problem p.s should not be more then $15 oh just tell them it came of the TB too
Nope, just goes by the name 'hose'
Measure the diameter of the hose and the legnth you need. Local auto parts store should have a wide assortment of hoses. :talon:
I'm pretty sure those hoses are molded. it'd probably be best to use OEM pieces, but i doubt using regular hose from autozone would hurt.
Make sure you measure the Inside Diameter, otherwise you may have some fitment problems ;)
-scott
    • dsmmario
    • Detail
    • dsmmario
    • Canadian_CD9A
