Spector5
- 274
- 6
- Jul 31, 2011
holland,
Michigan
So took the talon out for a drive down the street, and got going into second gear. After picking up the RPM's a bit I hear a loud clunk noise like something hit the bottom of the car.
First thought was I left a bolt or dropped a bolt in the bay somewhere and it finally fell out.
Second thought was something in the suspension let loose.
So I limp it back to the garage and notice my oil pressure gauge(stock OEM dash gauge) is barely doing anything and occasionally will almost reach the low mark. Also, once the rpm's reach 1000-900 the oil warning light will flicker on and off.
With that said I'm really leaning to either the oil pump took a crap or the pickup tube broke(Due to still getting some kind of oil pressure)
The reason pump or pickup issue didn't come to thought was the motor sounds fine, and I thought I would be able to hear the parts bouncing off my crank. However, then I remembered theres the windage tray and if it fell to the bottom of the pan it would never reach the crank.
Should I hook up a manual oil pressure gauge to the motor or should I just start tearing crap apart and pull the pan?
