Take a gander at my stupidity....
'93Talon
Sep 22, 2009
Boiling Springs, North Carolina
I needed to move the talon up the road since my attempt at a roll start failed (bad starter probably). Plan was to hook the tow strap up to the MR2 (irony here for those who know how I did the motor swap into the MR2) and back it up and park it again. There is no tow hook under the rear of the vehicle so I put the strap around this brace. I had used it before I thought, so I figured things would be fine. NEWB! Here is the end result.
Check out the rear wheel alignment now. Can you say crabbing much?
I should be able to head to the scrap yard to get that piece for pretty cheap, but I am not sure exactly if that will fix the alignment yet. I figured I would let you guys laugh at my stupidity.
i figured I would make you guys feel better about mistakes you have made working on cars. LOL
Junk yard will probably want $100-150 for the axle, and a new lateral rod from Mitsubishi is only about $40. Maybe the junk-yard will just give you the lateral with the axle; it's one less screw for them to take off.
DSM Graveyard wants $100, with the lateral, it looks like.
http://www.thedsmgraveyard.com/product_p/1314.htm
Looked at the pictures before i read the explanation. Looked like you had hit a jogger and torn a bit of his/her shirt off after dragging him under the car for a few hundred feet. Thought to myself "this thread could be incriminating"
Ok ill bite heres my gander at the situation
Since you have already got your answer enjoy the goose
No, I will be getting one from a local DSM guy for $20 bucks, and yes, it will be easy to replace.
nice! maybe that is what really happened and this thread is a cover up and you guys are witnesses :shhh:
Really though, that is the tag from the tow strap apparently. I left it there for effect. Not sure how it is sticking there, but whatever. LOL
