Holset WH1C damage
SlowChild3
545
9
Aug 19, 2005
Dayton, Ohio
I bought this turbo with shaft play and saw small amount of damage. Then I got home and took it apart... Is it scrap?
Could this be polished out? What kind of clearance is there from blades to housing?
Sent from my DROIDX using Tapatalk
Going to need a new compressor and cover, for sure. Also, a lot of times when thrust play is that much, the back of the turbine rubs on the heat shield, and gets damaged also.
^ What he said. You need to check the turbine wheel for damage.
Definitely suffered from a thrust failure. This is the reason that thrust wear is the worst to have- it results in wheel damage much quicker than journal bearing wear.
Personally I'd find another core. You can buy good H1C / H1E cores for much less than what it would cost to replace the wheel and cover on this turbo.
The sad thing is I've repaired turbos that had much worse damage than this from thrust wear for customers who were too cheap to fix them the correct way. If you rebuilt it, chances are it would perform just fine and you'd never notice any lack of performance.
That's not sad, that's good. Im going to rebuild it and put a new wheel in it and hope for the best. After that ill have $200ish in the turbo. Could have gotten better but you can't get all the good deals!
I bought the 58mm upgrade from Gillett Diesel. Great guys, fast shipping, and awesome product. You will not be dissappointed if you go that route.
not this has anything to do with the h1c but i bought a replacement turbine wheel for my hx40 and i definitely could have bought another one at that price
Does anyone know if i can send it out to someone for a 58 or 60mm bore?
You'll have to buy the compressor, cut the center housing for the larger wheel to fit, and buy a new compressor cover (you can't bore a 54mm H1C / HX35 cover to accept a 60mm wheel because of the MWE groove), and have the rotating assembly rebalanced. Be prepared to spend $300-$350 on getting this done.
If I were you I'd just clean everything up and rebuild it as-is. You have nothing to lose if it doesn't work out except the price of the parts kit.
Im gonna measure the compressor tonight to see how much got cut off. I assume it will still build boost but be slightly more laggy than normal. I haven't got the shaft out yet let's hope its not bent. :( let this be a lesson to everyone buying a blown turbo! Don't just look for visable defects, open it up! Thanks for your help jusmx
I was just thinking of this! Not to thread jack, but say your average mechanic was going to rebuild their turbo. We would still need to have the new assembly balanced, correct? And where are places we could take that to be done?
The H1C's and H1E's are all assembly-balanced from the factory. There are alignment marks that you must follow during a rebuild. If you replace one of the wheels, you risk the assembly being out of balance so it is recommended to get the assembly rebalanced.
Any turbo shop should be able to help you. The same machine that balances rotating electrical parts also balances turbochargers. I'm working on getting one of these machines for my own use, but I can't justify the $15k+ price tag at this time.
If you look at my first picture you can see 3 pieces missing on back of compressor wheel. Is this damage or balance?
Balance. MHI and Holset will grind the outside edge of the wheel; Garrett will grind the back of the wheel (not visible without removing the wheel).
15k Is a pretty high price tag for one of those things!! geeze!!
Are you shitting me? The VSR machines that places like FP use are $100k+ and have their own oil supply.
How much does it usually cost to have the rotating assembly balanced?
$45-$65 depending on the shop and the machine doing the work.
I really have no idea how much they cost or anything really about them. I was just sayin thats a crap load of money!! I would buy a new truck with that instead! :p But you would actually use a machine like that so I can see why you would want to buy one! Oh and thanks for the info Jusmx!
Doing a little polishing figured id share with this thread. Luckly im able to use good tools from work. The dynafile is great. I shaved the housing. Gonna take off rest of coating with the dynafile. Ill start with some 600 grit paper and then 1000 grit. Then hopefully ill be popin pimples in it after some buff wheel work.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
