Hmm to use this (New) HG or not
90turbotsi
244
4
Sep 15, 2002
Owings Mills, Maryland
Brand new OEM mitsubishi multi layer headgasket, it was sitting around the shop and got rubbed by something. The corner oil passage seal has a bit of rubbing on it, check out the picture below and let me know what you think. I can spray the gasket as well to help ensure a good seal, or if I have to ill get a new one. The motor is not a race motor but will see some boost so Id rather be sure and safe now then sorry later.
Thanks
LaN- said:
ask yourself this ....... do you really wanna run the chance of having to pull yoru head 2 times?
This is comming from someone with 2 audiobahn subs mounted on the rear cargo cover, wow.
I would personally use that HG. Copper spray it and call it a day, that shouldn't leak/bust.
Even if it did leak (highly unlikely IMO), then its really not that big of a deal to pull a head.
WoW..............................................................................................................
someones not an asshole
i never said it WOULDNT work, but the slight chance that you have to put another 5 hours of work into your car removing the head because you didnt wanna spend 100 bucks sounds alittle stupid to me, But hey i have speakers in my car so what do i know :toobad:
I wouldn't use it! Your going to run it on a race motor which is going to see high boost. I'd rather replace it now and sleep at night!
Thanks for your replies, power=dsm...Its going to be a driver and not a race motor but yes I was planning on replacing it just wanted to see what you all felt about it. My dealer had it in stock so I figured before I ventured over id ask around... oh well my discount made it only $73 but its more the fact I know its perfect now.
i would have used it. it gets compressed a lot more then that as soon as you torque it down anyway.
im pretty much SURE it would be fine as is and sure it would with a quick spray gasket coating. I just know my luck and dont want to have to deal with a head swap. If some one wants it PM me...not for free tho. But all in all I figured its better for me to be sure now then worry. Plus lets not forget this is going on my own personal car that I plan to daily drive ;)
It doesn't really matter how much boost he is going to be running, that is at the oil passage. IT IS NOT GOING TO LEAK. Use it. I have used far worse than that before.
well its kinda too late now, ive got the new one here and paid for. I will keep the other around, with putting a few motors together a year im sure it will be used. I am glad tho that its usable :)
