hks bov popped out
shallowshowcase
147
Jun 29, 2005
Arab, Alabama
after fixing alot of boost leaks my hks bov screw popped out some how i guess it pushed out with boost, or it was just too loose. i am NOT venting.... is this a major boost leak i need to fix, or can i just screw any screw that fits into it, or do i need to order another HKS brand screw
Same exact thing happen to me on my greddy type s. I jsut found a differnet screw and i put some of that white tape stuff on it so it didnt leak. Not a good solution wish somebosy would answer this for us but it has worked for past few months.
This is probably horrible advice, but I just took the top part off put a few quarters at the top to act as a blocker and stiffening device, that way it would be stiff enough and not leak. I also filled the screw hole with rtv.
1. New bolt with nut(Will be used as a jam nut)
2. J.B. weld the hole closed.
Yes, you will have a boost leak. The bolt adjusts how far the valve will open. i.e.-bolt all the way in, valve opens a little, bolt all the way out or no bolt, maxium valve travel.
  • Wanted 6 bolt NT water pipe
    • chrisman287
