Hit the track last night!
NMFDChris1G
113
Feb 21, 2006
South Plainfield, New Jersey
I dont think I did good at all, being it was my first time racing at the track an all but heres how it is. My first run I ran a 15.6 with a R/T of .349 an a MPH of 94.10 then I ran a 15.194 at 96.20 then my last run I ran a 14.850 with a MPH of 97.05 so can anyone tell me whats wrong LOL sorry for the stupid post I just thought I coulda done better! :notgood:
from the sounds of what you said, its all in the launch. with high 90's traps you should be in low 14's - high 13's
what are your 60' times?
what RPM are you launching at?
In your profile it says that your 60' os 2.165.
If you work on that and get your launch down. Then you will be much better off.
yea my best 60ft was a 2.165 an I was launching at like 4500-5000rpms but I couldnt get the launch perfect it would buck a little then go
Heres the log from the run, and yea I think it was my launch I get nervous launching it cause I dont wanna mess up the ACT 2600 cause I know it can handle it but then again its a DSM
TIMA AIRT FTRL FTRM FTRH FTO2 O2-R TPS MAFS RPM KNCK INJP O2-F IDC
33° 123.3°F 118.6% 115.4% 118.6% 99.8% 100.0% 924.6Hz 3656 0 12.03ms 2.96V 37
16° 123.3°F 118.6% 115.4% 118.6% 99.8% 100.0% 641.6Hz 2969 0 10.50ms 2.96V 26
21° 123.3°F 118.6% 115.4% 118.6% 99.8% 100.0% 1144.8Hz 4281 1 15.62ms 2.96V 56
19° 123.3°F 118.6% 115.4% 118.6% 99.8% 100.0% 1604.0Hz 5656 0 19.46ms 2.96V 92
22° 123.3°F 118.6% 115.4% 118.6% 99.8% 12.5% 1541.1Hz 6500 0 1.79ms 2.96V 10
44° 123.3°F 118.6% 115.4% 118.6% 99.8% 100.0% 1138.5Hz 4094 0 15.10ms 2.96V 52
18° 123.3°F 118.6% 115.4% 118.6% 99.8% 100.0% 1534.8Hz 4531 0 17.66ms 2.96V 67
19° 123.3°F 118.6% 115.4% 118.6% 99.8% 100.0% 1604.0Hz 5094 0 19.97ms 2.96V 85
19° 123.3°F 118.6% 115.4% 118.6% 99.8% 100.0% 1604.0Hz 5594 1 19.71ms 2.96V 92
21° 123.3°F 118.6% 115.4% 118.6% 99.8% 100.0% 1553.6Hz 6063 1 13.06ms 2.96V 66
25° 123.3°F 118.6% 115.4% 118.6% 99.8% 38.0% 352.2Hz 5938 0 11.78ms 2.96V 58
18° 123.3°F 118.6% 115.4% 118.6% 99.8% 100.0% 1490.7Hz 4375 0 17.41ms 2.96V 63
18° 123.3°F 118.6% 115.4% 118.6% 99.8% 100.0% 1604.0Hz 4656 0 18.94ms 2.96V 74
18° 123.3°F 118.6% 115.4% 118.6% 99.8% 100.0% 1604.0Hz 4875 0 19.97ms 2.96V 81
17° 123.3°F 118.6% 115.4% 118.6% 99.8% 100.0% 1604.0Hz 5125 0 21.25ms 2.96V 91
19° 123.3°F 118.6% 115.4% 118.6% 99.8% 100.0% 1604.0Hz 5375 0 20.99ms 2.96V 94
20° 123.3°F 118.6% 115.4% 118.6% 99.8% 100.0% 1182.5Hz 5438 0 17.92ms 2.96V 81
20° 123.3°F 118.6% 115.4% 118.6% 99.8% 10.6% 301.9Hz 4906 0 10.75ms 2.96V 44
20° 123.3°F 118.6% 115.4% 118.6% 99.8% 100.0% 1572.5Hz 4344 0 18.69ms 2.96V 68
18° 123.3°F 118.6% 115.4% 118.6% 99.8% 100.0% 1604.0Hz 4469 0 18.94ms 2.96V 71
18° 123.3°F 118.6% 115.4% 118.6% 99.8% 100.0% 1604.0Hz 4594 0 19.97ms 2.96V 76
18° 123.3°F 118.6% 115.4% 118.6% 99.8% 100.0% 1604.0Hz 4688 0 20.48ms 2.96V 80
18° 123.3°F 118.6% 115.4% 118.6% 99.8% 100.0% 1604.0Hz 4813 0 20.74ms 2.96V 83
17° 123.3°F 118.6% 115.4% 118.6% 99.8% 100.0% 1604.0Hz 4938 0 21.25ms 2.96V 87
17° 123.3°F 118.6% 115.4% 118.6% 99.8% 100.0% 1604.0Hz 5063 0 20.74ms 2.96V 87
18° 123.3°F 118.6% 115.4% 118.6% 99.8% 100.0% 1604.0Hz 5219 0 21.25ms 2.96V 92
18° 123.3°F 118.6% 115.4% 118.6% 99.8% 100.0% 1604.0Hz 5344 0 20.48ms 2.96V 91
you didn't log RPMs? I think you might get a better sampling rate on your logger if you only log the necessary parameters.
Oh.... I see it now.... :coy: It was lost in the 13 other parameters.
It looks like your main concern is your launch technique.
