high idle when cold
timsturbotalon
115
Nov 19, 2008
blacksburg, Virginia
when i remove the emissions i came across high idleing when car is cold,:talon: like 2500 rpm. after it warms up its fine. just wondering why?
your idle air screw may have "blown" itself out a bit, I would check to see if its loose.
It is right on the throtlebody facing you in about a 3/8" hole.
That's typically normal until the ECT senses the coolant is the correct operating temperature. What emissions components did you remove?
If your FIAV is still connected, then a high idle when extremely cold is standard operating procedure. If it doesn't return to normal rpm range (750-900 or so) within a few minutes of warming up, then there is an issue.
As a reminder to everyone, please use proper spelling, grammar, punctuation, capitalization and sentence structure when posting. It really does make it easier to understand what you're trying to say, as well as help keep the search function working normally. Thank you.
