High Idle AFTER 20 mins of driving....could it be fuel issues?
Red97GST
Mar 21, 2002
College Park, Maryland
After warming up, my car idles at the normal 800rpm.
After my car heats up, and i drive it around for maybe 10-20 mins, the idle will stay at around 1200-1500rpm. It wont waver up and down, it will just choose an RPM and stay there.
The car has been doing this for months. I recently had a blown head gasket replaced, and figured maybe the problem was stemming from the overheating I was experiencing.
But the problem remains there. EGTs will be higher, at around 500 C, rather than the usual 400-450C. I attribute this to the higher RPM, though, more than any real overheating.
I'm running essentially a stock set up. T28@15psi with a stock fuel system minus the 190lph walbro.
The car will idle fine after it warms up. But after some city driving, the idle will go up, and STAY up.
I haven't tried messing with my BISS screw or anything else, as I assumed if I lowered the idle when the car is heated up, that it will idle too low until it is driven harder, and this only masks the real problem anyway.
I believe the o-rings on my 450's are going bad. Not sure if this could have anything to do with it. I know the car is running real rich after putting in the fuel pump, as indicated by the blackness above my muffler on the rear bumper.
I couldn't find similar issues when searching for idle problems. Any input??? Thanks in advance
I would suspect a either a vacuum leak after your throttle body, or a too tight throttle cable. Its possible that it gets tight enough to slowly increase the throttle once its warmed up.
hmm i didnt think of the throttle cable being too tight. could it just tighten on its own over time? i havent messed with it in years.... but i will check that out tonight
    • george bromwell
    • pma1123
    • Sdcryan1
