turbo addict
- 482
- 1
- Apr 17, 2005
Omaha,
Nebraska
I am planning on building a motor for my DD a 1989 mirage turbo 1.6L with an E316G. I want to run higher compression as I am limited on the turbo and would like to get the most out of my setup. I was thinking of going around 11to1 compression give or take, but I am curious what others think. What experience have others had with their setups. I currently run 40psi on me E316g and have pushed it a little farther once or twice. I also want to know if I will have high boost problems with that high of compression.
Thanks for you input.
and also I dont understand why youd want less displacement, keep the 2.0. The 2.0 should provide more torque but keep the same top end or better over the 1.6, unless you did something to restrict flow of the head. The 2.0 should always flow better than a 1.6ltr not just at lower rpms, especially given you were just revving out sub 9k rpm which a 2 liter is well capable of so I dont understand that part. Also, If I didnt hit 40+ psi myself on my e316g i wouldnt have believed you managed to hit 50psi on yours, that open 4in exhaust really will cause that. I run open DP. A friend of mines hasa 35r that he cant control the boost on anymore when he upgraded to a 4in DP. It really makes a difference. My evo316g blew shortly after those high boost pulls, crazy yours can handle 50psi for so long... Im curious what your car dynos, and what that forrester intake did for you. I like the way my Hawver intake felt with my 16g.Also ideally I would run 11.1 compression with ethanol regardless the turbo, I just dont have the time or money to do it on my car...
