helpppp
yeiko
Jun 19, 2010
edison, New Jersey
i got a 97 talon tsi awd and everytime i start driving from a stop... i hear a click coming from the front right sometimes hard or sometimes you barely can hear it, does anyone have any idea????
also how can i connect my boost control, i have a line fron wastegate to turbo, i am not using the solenoid... please help guys
Do you still have the solenoid? If so, just look up the stock 2g vacuum diagram. Personally, I'd just pick up a mbc.
I'm going to put my money on a CV joint.
x2, Check and see if the boots are torn. My boots were torn and the cv joints went from clicking and progressively got worse and louder 'till I got a loud grinding noise.
I have a somewhat similar problem. I diagnosed it as my throwout bearing, because it rattles a little at idle as well, and when I push the clutch it stops. But when moving through the gears, (under acceleration) it clicks. Just something to think about if it isn't the CV.
Thanks everyone for replies I will check if it ch joints on my next day off
Ive had multiple throw out bearings go to hell and it doesnt sounds like a rattle.. Not like the noise the OP stated. CV joint or wheel bearing.. If its one of those you will need to replace the whole hub assembly.
Could be a ball joint, mine would clunk when i took off in my old car...it was just dry inside....it only had a bit of play, but enough to make a click click sound when i stopped or started off...could hear it a lot going through a drivethrough with a wall beside you to echo the sound.
