Help with Tranny seals and parts!?!
skatershawn
1,271
13
Feb 27, 2009
Austin, Texas
I have a used tranny that i wanted to replace all the seals on and stuff before i dropped into my car.. My old tranny is shot!
i was wondering if anyone could tell me or give me links to parts i need and where i can get them??
Im not rebuilding the tranny just want to replace the seals or gaskets on it cause i was told it leaks!
thanks!
ok.. i wuiold need to get two of these... one for each cv shaft?? Or is there two different ones?
AND also.. those aren't the gaskets i had in mind, i though i than you for the info, i will still need these!
Im talking about the tranny it self, there is like three gaskets that are inbetween different peices of the whole tranny housing! Where can i get these?
It looks as if the person before me tried sealing it up with rtv and fail or something because they told me the tranny had a small leak!!
I don't believe you you can replace the main output shaft seal (if that's the correct name for it) without a tranny rebuild. The other two seals (driver and passenger side) axle input seals are different.
I have replace the passenger side seal once and the driver side twice and still leak.
Good luck and let us know how it goes and what part 's you used.
