Help with some problems!!!
XyoungmurdaX
34
Jan 11, 2010
davie, Florida
ok so i just fixed my turbo leak but now whenever i hit it the turbo starts spooling and it makes like a whining noice kinda like if too much pressure was released idk but it didnt sound like that before, and i cant really check the noice too much since i just got my act 2600 clutch and im in the process of braking it in. and with the clutch its really really light it doesnt have much pressure on the pedal ive heard its like that for the break in period? and my front axle seems broken is that also why i notice a significant performance change??, and do i need to replace one of my motor mounts as soon as possible?
is the fins are bent or chewed does that i mean i have to take the turbo out and get new fins?? are they expensive?
Unhook the intake pipe from the turbo, grab the little nut on the wheel and test for shaft play by trying to see if it moves side to side, then try in and out. A tiny bit of side to side play is OK, but if it is moving in and out at all, the bearings could be shot and the fins will be scraping against the housing, making that whining noise. If so, the turbo will need to be rebuilt or better still replaced. Are you getting any blueish smoke (oil burning) out of the exhaust?
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
