Dragon TalonTsi
- 691
- 4
- Dec 5, 2005
Hobart,
Indiana
I have a few problems to share; #1- It feels like fuel cut, but I cant get past 4 1/2grand in any gear, whether I am boosting or not, no matter if I speed through or slowly get there, I cant get it, WTF???
#2- Lately, my car has had trouble starting, it turns over, but doesnt start fully (whether it's cold or not)... I have a feeling it is the fuel system, but i cant find the fuel filter, where is the location on the 4g63's, 2nd gen's and I need Pictures, of course.... #3- my plugs keep getting fouled, all the time..... I need some help bad, and I am not afraid to ask for help............
. Check your plugs. You should be running the NGK BPR6ES. Make sure they are gapped to .028. Check your wires and make sure you are getting spark to all of your plugs. Like you also said I would also change the fuel filter if this has not been changed yet. The fuel filter should be beside your battery on the firewall.
Do a leak test. Here's the procedure in case you didn't know about it:
HAVE YOU ACTUALLY PERFORMED A BOOST LEAK TEST?
I just paid him a lot of money for this, and i cant even drive my car, at all, it did start when i got it back, but now it wont even hold an idle, let alone barely turn over..... thanks for all your help..... w/b
