Help with my 95 gst electric problems
streetenvy
99
Mar 3, 2011
Port Charlotte, Florida
Hey guy i had posted that i was having electric problems with my gst every one has stated check fuse under hood in the car well i have done so and im still having this problem i missed four dayz of work due to this so my next question is does any one on this forum live in on near Port charlotte Fl or even Sarasota fl that might be will to take a trip to see what im dealing with and give your price on fixing this for me i would hate to sell the car for somthing like this problems im having No power fusible link 2 dome light diagnostic port, radio, luggage compartment floor lights there is a wiring night mare in my car so if you help ### contact me
Have you tried running an 8 gauge wire directly from your alternator to your fuse-able link?
You may have a break in your Alternator Main Power Cable.
I know my altenator should be putting out about 14.5v but is only putting out 12.5. Can that cause the problems I am having?
No but if your generator (alt) relay is toast and your dash charge light doesn't work, then your alt won't put out.
The post #2 is a good idea to try except I would first try from battery positive to that fuse just to make sure you get power there (since you should even without the alt working). You did measure power at both sides of that fuse with a multi-meter when you say no power there, right?
And did you measure the alt voltage at the alt or battery?
