Help with MAFT 2.02 "initial MAF mode setup"
Tsi_User
1,265
Oct 19, 2004
East Lansing, Michigan
Before I get flamed for searching, I did and still cant find an answer.
Im currently trying to tune the initial MAF mode setup on my 2.02 MAFT with a logger/MMCD. I already have the MAF sleection done and adjusted the BASE knob to keep the total trim1 between 80-100%.
In the next step the directions say to perform some light accelerations in 4th gear starting at 2K and adjust the MID control if total trim value at moderate flows (300-400hz) is significantly different than low flow (100-150hz mid trim). It then says to increase acceleration to half throttle and be sure im running rich before trying WOT.
Can anyone put this into "dumb" terms for me? What different things am I looking at in MMCD? Are the moderate flows / low flow just the hz reading at that specific throttle? And what # should I be looking at to make sure Im rich before giong WOT?
Thanks in advance, Im really stuck on this :|
go make a pull and post a log, like jeff say's, a log is worth more then you can every say....
