Help with gaskets please
turbotsi90
96
Mar 4, 2008
Salem, Oregon
ok I just used some SeaFoam in my 90 tsi awd and I noticed that the gasket between the turbo and the manifold is leaking and the gasket for the housing that the o2 sensor is threaded in.
Can someone please help me find these 2 gaskets?
Thanks you guys
You can find them at JNZTuning.com. Just pull up there website and give them a call. As there website is kind of hard to find things sometimes. I can pretty much garantee they will have what your looking for.
thanks man for the really quick reply, I will check them out.
oh and are they pretty easy to install?
Yeah no problem, yeah there not to bad. Just depends on how bad the bolts are rusted. Thats going to be the biggest problem your going to run into, or snapping a bolt. Just keep a can a PB Blaster next to you when you decide to chage your gaskets.
I have the same problem. its not a big leak but I want to fix it.
When I do mine im taking the manny to the engine shop to make sure its not cracked
  • Wanted 6 bolt NT water pipe
    • chrisman287
