help with I.D on the gaskets?
talon_frost
194
Feb 10, 2008
Kitchener,
well a friend gave me a crap load of gaskets today from a 98 tsi awd any help on what there for would be great :hellyeah:
Will any work on a my 90?
Throw some letters on each one so people can respond like "A = xxx", etc. I see a BS belt, and gaskets for EGR, throttle body, TB elbow, fuel filter housing, exhaust manifold, intake manifold, and thermostat...and a water pump or CAS o-ring, rear crank seal, and what looks to be 3 cam seals, or front case seals.
will any work on a my 90?
Probably most of them, depending on your car's mods and parts. K and L may be for a 7-bolt... hard for my old eyes to be sure :)
A = thermostat gasket
B = spark plug well gasket (part of valve cover gasket set)
C = BS belt
D = throttle body elbow gasket
E = throttle body to IM gasket
F = EGR gasket
G = These look like small exhaust donuts (OEM cam and front cover seals would be brown like "H")
H = rear crank seal
I = water pump or CAS o-ring
J = fuel filter housing gasket
K = intake manifold gasket
L = exhaust manifold gasket
BTW - that looks to be a new timing belt in a bag at the upper left
If you aren't gonna use those for a while, seal them up in a large flat plastic bag so they don't absorb moisture and stay flat. ;)
  • Wanted 6 bolt NT water pipe
    • chrisman287
