ECMlink help with ecmlink
dsmer1
88
Sep 7, 2011
loganville, Georgia
i have just got my ecmlink to work, but have an idle surge. my airflow to rev is osculating between .33 and .49 and my afr est is surging from 14.7 to 17.1 and in some cases jumpes up to 21!
i need some tips and advise from veterans in the feild. thanks for any help.
and i need help posting my logs
First do a book leak test please. Then if you check ecmlink website they have video demo section to dial in your car that shuld get you started. Your airflownperrev should be about .24 and dialing in your injectors will all be showed in ecmlinks demo videos. Record logs with ecmlink with f12. Let me know how far you get from there.
boost leak test was a sucess. no leaks. im holding (when the idle is steady) a constant 19 in of mercury. i am very fimilar with the videos bus its hard to tune for idle when it surges. and i am concernd about the afr est.
still zero it out though correct? i have looked on the ecmlink videos and saw where he used the MAFcomp sliders to zero in his airflowtorev to .25 but its hard to do so with an idle surge.
Idle surge sucks LOL but you don't have to have exactly .25, .24 or would be sufficent too.
yeah tell me about it. haha. it just seems i cant get it even relativly close to that. ive gotten it to .28 at its lowest and it just osculates up from there.
Do you still have all your emissions crap? Do you have erg block off?
Yes.
Anywhere from 0.24-0.28 is acceptable.
okay i will do that asoon as possible. should that also help my afr?
yes my egr has been blocked and i have performed a vacuum delete.
ok nevermind then...I missed it in your profile
EDIT: Oh and please don't go wot just yet! 11.6* of knockret! :nono:
yes of course. i adjusted the knock senser activation to 2000 rpm and >0% tps and reviewed the log and and noticed those knock counts. plus i have 87 oct in the tank.
Guess I'm be the first to yell at you for putting 87 octane in your tank... you need switch that asap or will effect your tune.. after you fill with supreme reset your ecu by disconnecting your battery.
easy fellas. i had no choice. car was towed in my own neigborhood and it was out of gas and the only way to get it home was 87 oct. thats for the link. im just trieing to dial in my idle.
heres my log after the zeroed out MAF comp
Not the best idea but just as if you where to run race gas or e85 or 87 or 93 octane its not going to work the same. You need clear out that gas and follow that link then when u make changes you need to tune to the exact fuel your ganna use.
okay i mean like i said i got it working recently and am inexperienced. i apressiate the help and critazism. im just alittle confused
Now zero your global fuel and deadtime. Then go through checklist
ok both are zeroed. i will complete the checklist tomorrow. i appreiate your input
That's lower than it should be. You want to shoot for .26 but if you can't get that low (i.e. you have big cams), then you want to get it as low as possible.
okay. but i do not have the stock MAF. i have a 3" gm MAF.
Do you have the ECMlink GM MAF cable or are you running a MAFT?
MAFT > select stock MAS and make sure to have MAFT set for 450cc injectors and all other knobs/switches zerod out
GM MAF > select 3" GM MAF
That is because of the 87 octane gas.
There's honestly no real point of trying to tune on 87 octane. Just drain the tank and go put in the highest octane you can get (probably 93). Then zero everything out in link - everything. Then go through the checklist and post back.
im running the ecmlink gm maf cable and i made shure i selected the 3" gm maft. im halfway through the checklist and i post back soon.
.24, .25, .26 is good enough, its not rocket science it doesn't have to he 110%. Anyone should be good with being close to those numbers.
