help with Control Arms . . .
ALLeyesONmyGSX
138
Jun 9, 2004
Los Angeles, California
hey guys i have a 99gsx and i dropped it on H&R sport springs, 1.7 front 1.4 rear . . . my tires are looking like this /---\ yes, they butterfly, and i was gonna purchase some new tires soon because the ones im using right now have completely worn down on the inside wall, where can i get front and rear control arms from ?
Did you have the car aligned after you dropped it, and if so what toe settings did you use ?
Charles
no, the car was not aligned after the drop, i just tossed on the springs and began driving . . .
That's why you wore your tyres out.
Get the car aligned, optionally remove camber from the rear, fit new tyres.
To remove the rear camber ask the alignment shop to use GM alignment shims behind the rear A-arms.
Charles
  • Wanted 6 bolt NT water pipe
    • chrisman287
