eSCAPEist_
- 116
- 1
- Dec 1, 2010
Decatur,
Alabama
I'm having a problem with my first DSM, which is a 97 GS N/T. I turn the key with the clutch in as usual, the car cranks and TRY'S to turn over for a half second or so and then it just clicks if I hold the key there for a sec. Yesterday morning at about 7:35am I had the same problem, It was a little cold outside and it just wouldn't turn all the way over, then that afternoon at about 3:00pm, it was warmer outside, I tried it and it did the same thing. I hooked up the jumper cables to jump it off with another car and at first it still woudn't turn all the way over, but after about 7-8 tries it fired right up and I drove it to work and it sat off for 4 hours, then it fired right up after work and I drove it home. It is now 8:00am the next day, still a little cold outside and it still tries to turn over but no fire. I've been trying to jump it off all morning and it's still a no-go. I'd really appreciate it if anyone has any ideas on this problem. Thanks,
-eSCAPEist_
-eSCAPEist_
Get a new one and you should be good to go.
