HELP!!! vacuum line mess..........
robs90tsi
808
13
Jan 26, 2006
grayslake, Illinois
ok, ive been searching everywhere for a solution to my problem, and i cant get any staight answers. My tsi has a freshly rebuilt motor, with under 1000 miles, and i had it rebuilt by a well known DSM guy in my area. I went to hook up my autometer boost gauge, and the typical vacuum line underneath the brake fluid resivoir used to accurately do so just doesnt exist on my vehicle. It appears that almost all my vacuum lines are either missing, short-cutted, or cut off. No solenoids, nothing. I have no idea if im missing any important lines or what. I would really like for someone to direct me in a direction here as to where i can figure out where all these vacuum lines are supposed to go. Basically, what lines are essential, what needs to be capped, and so on.
http://www.dsmtuners.com/forums/showthread.php?t=198327
Diagram shows the stock configuration and what is safe to remove.
and the typical vacuum line underneath the brake fluid resivoir used to accurately jusdo so t doesnt exist on my vehicle.
If you're talking about the brake booster line connected to the rear fitting on the intake manifold, there is a check valve in the stock hose, I suggest picking up an OEM replacement.
thank you, those help a lot, i can at least understand what i have and what i dont, and more importantly what i should cap, thanks
