HELP turbo drain to pan
nosturbo
May 16, 2006
troy, New York
do i just unbolt the 2 bolts and slide the gasket on and retighten? i dont have to drop the pan do i?
There should be a small crush washer on the drain tube bolts that should be replaced along with the gasket between the drain tube flange and the oil pan each time you remove the drain tube. People miss the crush washers all the time and wind up having an oil leak. They seal the bolts.
Steve
