HELP: rad. broke where hose goes.
HondaStalker said:
where you put your top rad hose on, that thing broke off, is their anyway at all you can put it back together.
well lets see you might be a able to find a shop that can weld plastic they can put it back together. next time don't lean on it.
a new radiator from a local parts store will be about $115
so if you find a master welder to weld plastic post his number to
i didn't lean on it, and if you also mean lean/rich, its all stock.
I was just driving and then white smoke started pouring.
Silly idea to make plastic endtanks that get brittle after 13 years... I just had to replace my radiator after the endtanks started leaking. I got an all-metal replacement for $105 shipped from Radiator Barn. They had it to my door in 2 days from when I ordered - pretty impressive.
