Need to find where hose goes....
Harriz801
187
Jan 12, 2005
Holland, Michigan
Well im in the process of putting my motor back in and alls i have left is to find out where one hose goes... alright i dont know what the part is called but it sits right underneather the battery and things connect up to it from the intake manifold.... its black and has to connections where hoses would connect on the top of it...the one i am looking for is if your on the passenger side of the car is the one on the right... i cant find any kind of hose for it... so i was wondering if someone could tell me what this is... where it goes and what it connects to... Thanks in advance...
Charcoal canister? It connects to the intake if we're talking about the same thing. Black cylindrical can? That's it. I think it sends the fuel vapors from the gas tank back to the intake.
It sounds like you might be referring to the evaporative canister. A pic would help.
Well i just went out and took a look at it... the diagram was helpful to find where hoes' go but im still left with nothing... i cant find any loose hoses or anything... the only other thing i found was that on the can it was marked AIR... so could that be some kind of breather hole or something... because it doesnt show any marks of a hose being there before...
Nope everything is hooked up to the intake... i think the one you are thinking of is hooked up right underneath the hole that i am talking about.... that ones it hooked up to what looks like a filter or something that comes off of the can?
You're correct. The one that goes to the intake is hooked to the purge control valve, I believe. The connection your referring to is vented to atmosphere as you thought. I jammed my hand underneath the battery tray, and found it was vented to atmosphere. Sorry to bum dope you.
Has anyone ever removed that canister before? I removed mine and now it takes a little while for the car to fire up. it just cranks and cranks? I dont mean to steal the thread or anything, I just thought it would be a good place to ask since thats what you guys were talking about.
