dacowgod
Supporting Vendor
- 464
- 289
- Feb 3, 2006
Morgantown,
West Virginia
Any general ideas what my problem would be..
I have a 95 GSX running 17 lbs of boost from a PTE 5027 50 trim .. 880 injectors 255 pump comp cams 101200's with all the supporting mods. Anyways heres the problem.
DSMLink reads 23 lbs of boostest while i'm only running 17 lbs. DSMLink reads AF/R at 11.62 during boost while my wideband reads around 10.5ish Timing according to dsmlink never goes over 11 and i see anywhere between 4-8 degrees knock. from around 4500 - 5k until i let off the gas..
All the props are set correctly in boostest and A/F and also LTFT and STFT are good..
I havent tried tuning on the 50 trim at all i have been very conservative with it and really havent even driven a tank of gas on the car since its been on there because I wanted to install the wideband before I went out romping on it..
On my Evo III 16g I had installed previously I never had a problem with knock at 20 lbs and boostest was always pretty close above 5 grand.. .. but I was setup then on a 190 pump 650 fic injectors and stock cams and no wideband... Timing was always low on that setup too though..
seems i see guys on the boards all the time running 22-24 lbs of boost on a 50 trim with 93 octane and 20 degrees timing and no knock... dont know why i cant do the same?! .. any suggestions..
