2G Help O2 Sensor Log?
talongod
274
Nov 24, 2002
Mayfield Hts., Ohio
Ok my check engine light was on for fuel trim malfunction p0171 now it is off and back on for o2 sensor 2 p0141 which is the one behind the cat, but my pocketlogger says o2sensor 1 is reading 0 and o2sensor 2 is .6 but o2sensor 2 is broken i can tell and o2sensor 1 the wire was showing so i put some silicone on it
any input plz thanx
the second o2 sensor shoulkd have no performance effect at all, just an obd2 thing, it will just show a cel. you probably had the fuel trim code due to the first o2 sensor going bad because thats what will give you your fuel tim readings. use your logger to determine the problem becaus eif it was shot, the o2 trims would be going haywire when under full throttle. id replace the first o2 sensor and see if it helps.
  • Wanted 4G63 800cc injectors
    Im looking for a set of injectors that are at least 800cc. Thanks!
    • DSM_Thorpe
  • For sale 2g 2g rear brace arms
    2g rear subframe brace arms. Missing one of the bushing spacers. No rust. Had someone looking...
  • For sale 1g 1GB Eclipse Tail Lights
    1GB Eclipse Tail Lights $80 + shipping and paypal fees* not flawless but in very good shape...
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
