Help Name This Holset
Bergness08
34
Jun 27, 2013
Mason City, Iowa
Hopefully the images come in clear enough to decipher. I am looking at purchasing this turbo, but can't seem to get any numbers on it to cross reference. I was thinking it was an HT60, but from what I understand those are reverse flow. I Think the casting number on the exhaust housing is 3532410 or 35333410 or 3538410. I can't really tell what the 4th digit is. Any help is greatly appreciated. Thanks in advance.
That looks like a 23cm or 28cm HX60. You're correct about the HT60. They do spin the opposite direction of the HX series. It's got a weird Holset inlet (similar to T6 flange), weighs like 70lbs and good for ~125lbs/min.
Rotation direction shouldn't matter as you would be making your own manifold and piping for it anyway for whatever you plan to put it on.
You wouldn't want to use that turbine wheel/housing on anything but a compound setup or as a single on a max effort 4G63. There are other options for a compressor that size with better hotsides for our cars.
Thanks a bunch land speed. I will probably just use it as a wall ornament until a suitable project comes along, I just wanted to know what it was first.
Thanks again.
    • dsmmario
    • Detail
    • dsmmario
    • Canadian_CD9A
