Resolved Help ME!!!! walbro 255 install
j_woody
142
Dec 26, 2002
seattle, Washington
I am installing a walbro 255 pump in my 95 gsx. I am trying to get the fitting off of the main line from the bottom of the car. I broke it loose and it spilled gas everywhere but if i keep twisting the nut it gets tight agian. if i turn it back to the other way it also gets tight. wtf do I do to get this thing off?
I am tryin to put in a walbro 255lph pump. i have a 95 gsx. I cannot get the fitting on the bottom of the car on the main line off. it broke loose but will not come off. it gets tight no matter which way you turn it. How do I get this thing off?
it just keeps getting tighter and tighter. is the hose supposed to turn or are the nuts just supposed to turn off of each other? is it supposed to be easy after the nuts initially break loose?
sorry, i am in a bind and need to get this figured out asap. i am screwed if i dont figure it out soon
ok, i can only turn it so much and then it tightens back up. if i twist it any harder i am afraid of breaking it.
