help me out please
CRAIG___
54
Apr 22, 2008
KING, North Carolina
ok my gst last night messed up knocking really loud should i rebuild it or i have a 93 eagle talon with a 6 bolt motor swap n it can u put the 6 bolt in my 95 gst with the 7 bolt transmission because the tran in the talon has a slight grind in 3rd gear
Yes you can swap the motor into your 2g if you want, its not super easy but if youre determined to do it it can happen.
You can still use the 2g tranny you just need a 7 bolt flywheel which you probably already have.
