Help me identify this MS system a little better
99RedGs
520
7
Jun 28, 2007
Somewhere, Wisconsin
Hi guys,
I'm looking at purchasing this MS system from a guy on 2gnt and I was wondering if someone might be able to tell me everything that done to it (internal ignitors?, etc...)
He doesn't know a lot about it, but it was assembled by Terry ( Star Turbo Talon).
From the pictures he posted I can tell it is:
- MS1 chip
-V2.2 board
-3bar MAP sensor
I'd be getting the GM sensors, harness, injector harness, software, data cable... I'm hoping this should be everything to get this up and running, but because of the lack of info I'm reaching out for some help.
I'll also have a 1:1 regulator, 255 walbro, RC 550cc injectors.. Anything else I might be missing for some reason??
Also, I was planning on upgrading to an MS2 daughterboard in the future, I realize I am limited by the v2.2 board, but I should be able to run fuel and spark still right?
Thanks guys,
Aaron
Yep, it's definitely a v2.2 board with MS1. It's got a flyback board, so you can run low impedance (low Z) fuel injectors with no external hardware. The ignitors are usually installed on the underside of the board, along with the MAP sensor, so I can't verify those things. It seems like it has internal ignitors installed given the two nuts mounted below the DB37 connector.
It sounds like it includes just about everything you'll need, but if the "data cable" is a standard serial cable, you'll need a USB-serial adapter to connect to the ECU (unless your laptop has a serial port). Also, it sounds like this ECU was built a while ago, so be sure to update the software. TunerStudio MS is the preferred tuning software and MS1/Extra 029y4 is the latest firmware release.
You should be able to upgrade to MS2 and still run fuel and spark just fine.
Just the guy I was hoping to hear from :) Thank you, Im sure I will have more questions about this once it arrives LOL ( I'll pull it apart and show the underside for verification). Ive read all of the manuals and info I can find (2gnt write-ups as well)
