Spoolin98
- 1,646
- 24
- Feb 1, 2004
Easton,
Pennsylvania
Ok so here is what happened. I was on the highway on a hot day and I did several back to back full throttle pulls. On my last pull I was letting the engine brake itself from about 5k rpms down and I felt the motor kind of jump or hesitate a little. At this point I thought the timing belt skipped. I looked down at my gauges and saw my oil temp gauge maxed out at 300* plus. So I immediately shut the car off and pulled to the side of the road. There was smoke coming out of the valve cover when I removed the oil cap. The dipstick looked dry so I went and bought oil. By the time I came back the oil temp was down to about 120* and I checked the dipstick again and the oil was right where it was when I first started the car. I topped it off with about a half a quart and started the car.
The car started fine and idled fine for about 4 seconds and then a noise started, sounded like it was coming from the head. It wasn't going with the motor though. So I had my car towed home.
I let the car sit for a few days before looking at it, I needed to cool down. I pulled the valve cover, I found nothing obvious. I pulled the plugs and turned the motor by hand, still nothing obvious. It turns and gets a little tough at one point, but it still turns. And I don't hear any major malfunctions while turning it.
So I stuck a 10 inch 3/8 extension in the number one cylinder and turned the motor till it hit top dead center, both the timing marks on the cam gears line up perfectly. I didn't check the lower timing yet, but it looks like the timing is still on point.
So I drained the oil to see if it was broken down or separated from being heated to over 300*. I put a screen in my oil pan and drained it. It came out really thick, but didn't separate. After it was done draining I found 4 tiny pieces of metal stuck on the screen. They were so small and thin, as thin as or thinner than aluminum foil. You could pick them up and fold them in half with ease, just like tinfoil. I tried to pick them up with a magnet and couldn't, so I'm pretty sure they are aluminum.
Next I pulled the intake; the turbo spins freely and still no shaft play.
The motor has almost 5k miles on it and had the oil changed 8 times, is this wear in metal? Should I be concerned?
Everyone I talked to said its good they aren't chunks of metal, obviously. My one friend said he had the same metal in his pan after a fresh rebuild.
What do you guys think my problem is with the motor? Could it simply be the oil? Could changing it solve my problem of this noise?
Once I figure out what happened to my motor, I need to find out why the oil over heated.
Could several back to back pulls with and external oil cooler cause your oil to over heat on a 85* day?
I'm just looking for ideas or possibly someone who had the same problem.
Let me know what you guys think, any ideas will help.
My next step is to pull the oil pan.
was there a warranty on your engine?
