help installing non cruise contol cable
Did you buy a non cruise cable?
If you didn't take the short stock cruise cable that should work, you just need to attach it to the back of the throttle body to hold it.
There should be a bracket with 2 10mm bolts that bolt to the back of the manifold, just like the stock one did.
I was going to say get a non-cruise cable for it or if not get a non-cruise cable from a 1g but looks like you already figured it out. I wish my gas pedal were a little softer but then again i want to keep my cc for the fact it works.
Why did you take out your cc if i may ask ?
so i just did my 6 bolt swap, and as u can see i have a sbr sheet metal intake manifold.
the t body was hitting the cc box that is mounted on the fire wall. but the cc worked fine, im sad i got rid of it:(
Looking at the pics you show... that's not a non-cruise control cable. The non-cruise control cable doesn't have the nut and stuff on the end and has the flange to mount it to the intake man already on it. It still makes a loop over the valve cover. It'll look like this here: 2g NON- cruise cable
They obviously gave you the wrong one. Like others have said there should have been a bracket and there shouldn't be those two nuts on the end of the cable.
And I would really consider taking off that bracket that you just kind of "stuck" on there. It looks like crap and it looks like it's going to fall off at any moment.
yeah that is 100% not the right cable, i snagged a 2g Non CC cable off of a car in the junkyard for my 1g works fine. hardest part was figuring how to loop it, i ended up looping it under the intake manifold so you can't see it.
Did you give the dealer your VIN #, bc i think he ordered the throttle cable that goes to the CC unit.
