Help Indetifying Holset Turbo???
abaum565
266
3
Aug 9, 2006
Wausau, Wisconsin
So I've read through the novel of threads on here about holsets. During that time I came by a deal on this Holset HX35 for $100 and couldn't pass it up. But from what I understand the Hx35's came with a wastegate (I think) and everyone I've seen has a anitsurge compressor cover.
Here is the one I picked up. No antisurge cover, no wastegate, and I couldn't find matching numbers from the tuners thread to cummins holsets. My best guess is that it came from a bus or large truck or tractor, etc. The model number is close to some of the bus part numbers but doesn't match exactly. I also think it's pretty old. I am also picking up a micrometer to measure the wheels in the next few days. What do you guys think.
It is 8 blade and divided T3.
it appears to have a V-band on the hotside, if you could look into the t3 runners and tell us what number is engraved in there it would help as that number shows the size of the hotside.
It is a v-band outlet. Here are the numbers on the inside:12 (I am going to assume this is a 12cm^2 divided T3)
Also numbers on the hotside: (probably don't mean much)
216400
3538310
TW2
Also on the other side (facing the cartridge) the numbers 11C3
Thanks for all your help!
depending on the compressor measurements, i would use that turbo with the stock hotside, it should provide nice results.
    • dsmmario
    • Detail
    • dsmmario
    • Canadian_CD9A
