ECMlink Help Idle log with new ported head and FIC 1650cc Injectors
stroh
84
5
Oct 17, 2002
Freeport, Illinois
I was hoping someone could take a look at my log. I recently blew a head gasket and decided to put my spare cylinder head on with a bunch of porting work done to it. I also switched to some FIC 1650cc injectors. The car almost sounds like it has a bunch of misfires. I have some white smoke coming out of the exhaust. I used ecmlink's calculator for the global fuel setting. I tried using the data sheet that came with the injectors and put in the voltage offset, but the car was running really rich and it was stuck in open loop mode. O2 sensor would not cycle. So I switched it back. I was hoping someone could check the log and see what they think. It's at the bottom. Thanks.
1). Any boost, vac, or exhaust leaks? No
Boost leak tested 5psi above your max boost with no leaks? Yes
2). Verified mechanical timing? Yes
3). Verified base timing? Yes
4). Ignition system
COP or Stock Coil: Stock
Wire brand and Age: 1 year old
Spark Plug brand, type and Gap:
5). Motor health (Compression Test)
Cylinder 1: 160
Cylinder 2:165
Cylinder 3:165
Cylinder 4:160
6). Performed basic throttle body adjustments?
Idle Switch: yes
Throttle Cable: yes
TPS:yes
BISS:yes
7). Compression ratio: 8.5:1
8). Any known bad sensors or brittle wiring? No
9). Any DTC/CEL codes? No
10). Electrical system
Car off (not running):
Car running: Yes
11). Base fuel pressure and injector values
Base Fuel Pressure: 43.5
Injector Size (cc/min): FIC 1650cc
12). Properly calibrated and configured wideband sensor
Sensor Brand: Innovate
Calibration Date: July, 23, 2016
13). Type of fuel
Type: 93 octane
Percent of Ethanol:
14). Watched ECMlink how-to videos? yes
Here's a couple problems I notice,
1. your airflow should be around .25 and you are over .50
2. Tps volts are at .61 and need to be at .63.
3. Your Omni 4 bar at baro is not working either for SD as it is stuck at 30.1inhg.
4. Your other boost source shows -8 to -9, do you have cams? If not it should be between 18-20inHG for either the Omni or boost source.
5. Your ISC is failing as well as at the end of log it drops to 11. Should stay around 30 or so.
Can you post a log at full temp 186 or above? Can you also use the FIC battinjsettings?
I have another log here. I put in the FIC battinjsettings and put the deadtime at 0. My tps volts are at .63 now. My omni 4 bar is set to display as MAP on the graph. It's reading roughly -9 to -11. I have HKS 272 cams. One thing to note is that with my other head and injectors I had Devin at Boostin Performance tune my car. When he was done my airflow per rev was around 45. That is how my car has always ran. It's never been close to the recommended value. Maybe it has something to due with the fact that it is a 2.4 Liter. Thanks for the help so far.
  • For sale 2g 2GB Manul/Turbo Engine Harness
    2GB Manual/Turbo Engine Harness $150 + shipping & paypal fees* wired for 1G CAS, CAS Included...
  • For sale FIC 1650 High Z Injectors
    I have a set of FIC High Z 1650 injectors. They are in great shape with only 500 miles on them...
    • jking29
  • For sale 2g Misc parts
    Have a few things for sale. Open to offers, located in Toronto Canada but can ship- S90...
    • Bedicine
  • For sale 1g ECMlink V.3 with Ecu and speed density cable
    I have a DSMlink V.3 with a socketed and recapped Ecu. It includes the cable, CD, and a brand...
    • jking29
  • For sale 2g Pilotos traseros europeos
    A la venta varios juegos de pilotos europeos, rojo y naranja en buen estado, envios desde españa...
    • javivds255
