General help identifying ECU
Stizzyflip611
85
Nov 21, 2003
Howell, New Jersey
i'm in the process of finishing up the rebuild on my laser and i plan to run dsmlink to tune it. i had bought a used ecu from gary at mitsu graveyard a while back and i just wanted to ask if it can be identified as a 91 turbo 5speed ecu from the part number. and will it work if i sent it out to the guys at dsmlink to get socketed for the software, etc...
part # MD166260... then there more numbers underneath that read....e2t36574
i would greatly appreciate any help from the wisemen
thanks alot
Yes, that is the correct number. MD16620 is a '91 fwd m/t ecu.
If the ecu is an eprom, then you can send it off to get socketed for the dsmlink.
To see if it is an eprom,
Hold the White female harness plug towards the top, then look on the bottom right hand corner for a processer.
http://i15.ebayimg.com/05/i/06/6a/82/df_1.JPG
There is a link to kinda show you what im talking about!
Here is a close up of the eprom chip!
http://i22.ebayimg.com/05/i/06/70/42/a6_1.JPG
thnx for such a quick response TKI... i took the cover off and theres no white eprom chip.. this means i cannot use this ecu i have for dsmlink?? if so, is there any way to mod the ecu so i can use it.. keydriver chip????
thnx again
