General having trouble identifying ecu
Spinner
Oct 11, 2017
Van Buren, Arkansas
According to the ecmtuning wiki part number MD321912 is a compatible ecu however this listing i found as well as many other that don't show the actual board have a T on the front casing which seems to be to the contrary of what is said on Ecmtunings site it should have an E.
Can someone please clarify?
MD321912 is a ECU for a 96 Turbo FWD car. The T means it's not an EPROM ECU. I don't think I've ever seen a EPROM MD321912 ECU only the two versions of the '95 ECUs MD312464 and MD309947.
What the ECMTuning Wiki mentions is that the MD321912 has to be converted Using their "2G non-EPROM conversion”. You should double check that ECMTuning still have the parts for the conversion available before you buy anything because I don't see it on their ordering page anymore and there were shortages last year.
