help identify borg warner turbo
my4ATEurV8
210
Jun 30, 2008
wausau, Wisconsin
i just picked this one up today for free so i figured what the hell, i give it a try.
the compressor housing says 51t/32 i think
how would this turbo compare to my hx37 7 blade. assuming that i kept both turbos in there stock t3 turbine housings
You try looking on Google or Yahoo for details or specs? That could be a start.
just curiouse. i picked it up for free and figured it could do somthing. if anything it will have very respectable spool, for a dayly driver.
this thing is in great shape as well. absolutaly no unwanted shaft play.
im not sure if there is a bolton housing for this particular turbo. anything is possible. it is a standard t3 exhaust flang and the housings arent as big as the ones on my 7 blade hx35, so im positive that you wouldnt run into any fitment/placement problems
i think im going to put this turbo up for sale. ill clean it up first of cource. its figured out that its just not what i want, so why keep it around?
I have one of these in my possession right now... were using it on a buddies sohc civic... heres the specs:
Borgwarner/ISHI RHC6 turbocharger.
Very high quality turbo featuring T3 compatible oil drain and turbine flange, bigger shaft than equivalent garrett turbos, double compressor seal and sturdy internals such as bolted-Down 360deg. Thrust plate and an integrated backplate.
Compressor wheel: 50.3 / 70 mm 52 trim
compressor housing: 0.7 a/r
center section: oil cooled journal bearings
Turbine wheel: 64.6 /62.1 mm 77 trim
Turbine housing: 0.7 a/r
internally or externally wastegateable.
