help i dont even know what to call it
chizbiscut
Aug 19, 2007
honolulu, Hawaii
my 98 gst runs fine as long as you don't push the throttle past 50%.
anthing past 50% throttle and the engine will stutter terribly, its like a horrible bog.
i can go 100mph plus, i just have to NOT floor it.
thanks alot for all the info i am working 13hr days so i will try out the ideas this sat.
what store are those ngk from.
i have ngks , how do you check your plug wires and coil? wht are good wires if i want to upgrade?
i did the boost leak thats what i am going to work on toight is the unkown huge leak coming from the back side of my throttle body!!! as far as mods i have K&N intake filter,tubular exhaust manifold, external dump o2 housing, 3" exhaust (strait piped) full emissions delete!
has anyone heard a wierd clicking noise coming from behind the throttle body when you turn the car
(only happens sometims and it will only last like 30sec)
what is IAC?
the problem was a boost leak mainly from the throttle body gasket wich is fixed. it still studers slightly, so i am still searching for more leaks thanks alot guys. just one more question, there is a screw on the throttle body that looks like its made to adjust the idle and i have a boost leak from there, how do you seal that screw??????
is there some special adjustment for that biss srew. what does biss screw mean.
does anyone know how to adjust the BISS SCREW
