help hooking my turbo back up
jsonic
Apr 15, 2010
florence, Mississippi
i got regular turbo hocked in it bt i got hook oil feed line and all up and there some weard things still poking out that look like they hook up to and i cnt se wear too hook it up if you thing you can help email me at [email protected]
Aside from spelling and punctuation issues with your post, you'll need to be clearer with what the problem is. A picture is worth a thousand words and will help identify what needs hooked up where. You also need to state what model of turbo or at least the manufacturer as different turbos have different requirements and different fittings for oil lines. Some don't use water/antifreeze to help cool the turbo either so we'd need to know things like that. Post a pic of the problem, it's the easiest way to find a solution!
