help, engine won't start sometimes unless i give some gas
caliburrx8
Sep 19, 2007
toms river, New Jersey
Gst engine won't start sometimes unless i give some gas, at first i thought it was the fuel pump but it runs fine after it starts and it only does it sometimes usually when its cold out and i drive it for for 10 mins and try to start it.
Temp sensor has gone kaput - why you have to hold the throttle open to start... and being cold as you say.
Don't know about that, I don't see how the temperature sensor would car your car not to start. I would have your battery checked at your local auto parts store, cold weather tends to drain batteries down, could be that. I would check there. If you have checked your fuel pump, you should be good there, I would go first with battery.
Look into the temp sensor, its happened to me before, had to cold start with brake clean b4 i got around to changing it.
that's wierd, must be a dsm thing, cause i have never heard of that. how does the temp sensor actually cause the car not to run? i mean i can understand cam sensors, and crank sensors, but have never heard of this
She is picky like that.
