Help diagnose... chocking/stuttering turbo? Starts up with difficulty
Tiki2777
1,104
147
Oct 9, 2011
Omaha, Nebraska
I had a boost leak because it would not build boost and it would buck/jerk like crazy. I fixed that, and it drove in boost nicely finally, but when i hit about 13-14psi, the turbo started to "choke," it didn't jerk or buck like a standard boost leak, it just didn't pull as hard as it should and it definitely didn't sound right. Now, it is starting to choke and stutter at a little lower psi, but it is still not bucking or jerking or hard to control the clutch like a boost leak. I don't have a clue what it could be. HELP:pray:
No I can almost guarantee it's not the "turbo choking". Check plugs, wires and look for loose connections. Do you have a CEL on? Boost leak testers are your friend. :)
