Help car misfires
1990talon
331
Aug 3, 2006
Federal Way, Washington
Check this picture of the upper timming cover, this happend when I was on my way to spokane from seattle. I got there and noticed that my car sounded like it was misfiring and then I popped the hood and this is what I found. :confused:
Also last night I cleaned my motor and cleaned my spark plug wires with bug and tar remover. could this be a problem? Please help I am in spokane and dont want to drive it home this way! :mad:
Thanks alot,
Brandon.
i would def change the spark plugs...my car was miss firing under boost and it turned out just being the sparkplugs...try that first its a cheap solution to the problem and if its not that its not like you just spent a lot of money...only thing i can think of...good luck
Thanks all try that and let you know it is just i have no tools over here so I will just buy a socket and wrench
Thanks agian
changed the plugs and wires but that didnt do it so I got to looking and then listened a little better and then it didnt quite sound like a misfire so I started to check for boost leaks and found I felt warm air blowing in my engine compartment so then I put my hand just under the exhaust manifold and felt a leak it turned out to be a cracked exhaust manifold so I think so I will pick one up today and put it on hopefully that will do it by the way made it back from spokane. :thumb: Ill let you know if that did it thanks!
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
