Help calibrating AEM-UEGO.
Chris_Sag
102
Sep 8, 2010
Bergen, Florida
As topic says, need help calibrating a AEM-Uego wideband for AF. Did not understand mutch of usermanual. Can someone help me? How to calibrate a instrument without any buttons?:S
The calibration is for logging, such as an input into ECMlink. The guage is already calibrated with the controller and sensor.
If your logging, the calibration need to be done in your logging software, in which i think ECMlink has AEM one on a preset.
Not sure what your asking but if your talking about Doing a Free air Calibration like a Innovate Lc-1. Your gonna have a hard time, since you can't.
This is the AEM UEGO 30-410 correct?
The Sensors are Individually calibrated with a resistor integral at the connector body with a sensor
specific calibration unlike others... .
NOTE: AEM White Paper are notoriously WRONG
White Paper >CLICK< but the scales of the AFR vs volt's is in their (note that is not completely right)
If your a little more specific what your asking We/someone should be able to help
Only thing you can change is on the back their an option to select different output voltage to log here is the scale that's selectable for the gauge
attachment.php
EDIT:I was slow to post,
I suggest that once you hook up the guage to disconect the sensor it will default 14.7 and verify that is your reading in Link Also depending on what input your logging to with out a buffer I doubt you will ever see a reading lower then 11.0:1
Click here for more info about using that sesor in Link
I am glad i read this post! I will be installing my AEM UEGO soon, thanks for the info!
i have my aem wb installed in the downpipe bung. Should i be running it in the o2 housing since im running e85? Thats where i thought it should go is in the downpipe but it seems that i should be running it in the o2 housing.
Not sure what would make you think that:confused: Or what E85 would have to do with it
But,
While people get away with running their W/b sensor in the o2 housings sometimes...
IMHO I wouldn't recommend it they aren't meant to be used it that manner... And with the AEM your not going even know if something isn't going right like some of the other W/d's on the market:|
Read Posts 6, 14, 16, 20, 22 in >This Thread<
for some more Info on what I'm talking about or the whole thing to put it in context LOL
I posted the link to that above...
