conquest TSi. aem uego help
chocolate
May 16, 2013
BRISTOL, Rhode Island
Hello boost junkies. Getting The wideband hooked up my starquest.
I know that the Red goes To 12v power
And the black goes to ground.
But im confused as to where The white or "0-5v" wire
Does the White go to the ecu or.... im confused? Alittle help would be sweet.
Just trying to see where the a/f is. Im going to Be running 3" gm mas to maf-t to 1g mass air clip. So any Ajdustments will be made with the maf-t.
Then the white wire is un-needed. If you are using any kind of tuning software, them that white wire would go to the ECU so you can see your AFR in your tuning device. So that your not using any tuning device just leave it alone.
The white wire is narrow band can simulate front o2 with this setup but I prefere to leave front o2 alone. Or for logging depending on what you use to log with. Not nessacary unless your tuner says. I just use then gauge to tune with.
Okay men today I got Home from Work and started The install. everything was pretty straight forward turned The sensor into The bung about 3/4 a turn. Didnt know if There was any Tourqe specs . I read the manual And it did not have any info on That. Tommorow after work, i'm going to Find a dedicated 12v power source for the gauges power. Any Suggestions on the Best 12v for the conquest specifically? Maybe the Fuel pump...
Did a quick lil pull and saw the car was running 10-1 richness in boost Which is why it backfires and breaks up under boost.
